Group: DynoMotion Message: 12804 From: daveymahomh600e Date: 2/20/2016
Subject: Strange Axis Activity
Hello Tom,
I have a KFlop/SnapAmp machine which is acting a little weird. There are 2 servo motors (X/Y axis) and 2 stepper motors (Z/A axis) and each group runs from a different SnapAmp. Occasionally the A axis stops physically moving while the readout keeps going.
The steppers are open loop, so I checked for jamming of the slide and loose couplings, but both were good. The funny thing is the screen jog buttons always move the A axis no problem, but when the motion is within gcode, it often will not move. A reboot of the system will usually restore normal movement temporarily.
Any thoughts on what may be causing this?
David.
Group: DynoMotion Message: 12806 From: TKSOFT Date: 2/20/2016
Subject: Re: Strange Axis Activity
Hi David,
GCode G1,G2,G3 commands use different Velocity, Acceleration, and unlimited Jerk compared to Jogging and Rapids.
See:
http://www.dynomotion.com/wiki/index.php?title=Main_Page#Velocity.2C_Acceleration.2C_and_Jerk
On 2016-02-20 12:34, david.m.stevenson@... [DynoMotion] wrote:
> Hello Tom, > > I have a KFlop/SnapAmp machine which is acting a little weird. There > are 2 servo motors (X/Y axis) and 2 stepper motors (Z/A axis) and each > group runs from a different SnapAmp. Occasionally the A axis stops > physically moving while the readout keeps going. > > The steppers are open loop, so I checked for jamming of the slide and > loose couplings, but both were good. The funny thing is the screen jog > buttons always move the A axis no problem, but when the motion is > within gcode, it often will not move. A reboot of the system will > usually restore normal movement temporarily. > > Any thoughts on what may be causing this? > > Thanks, > David. >
Group: DynoMotion Message: 12808 From: David Stevenson Date: 2/20/2016
I understand there are different settings for the 2 movements, I don't understand why one of the methods would stop working. Is this likely a problem with a SnapAmp? A G0 or G1 don't work, but there is power and signal for the other method.
David.
On 2/20/2016 1:06 PM, tk@... [DynoMotion] wrote:
Hi David,
See:
> Hello Tom,
> Thanks,
> David.
This email has been sent from a virus-free computer protected by Avast.
www.avast.com
Group: DynoMotion Message: 12819 From: David Stevenson Date: 2/21/2016
I guess there is something obvious here, but it escapes me. Any other clues of things I should do or check?
David.
Hi David,
See:
> Hello Tom,
> Thanks,
> David.
www.avast.com
Group: DynoMotion Message: 12820 From: Tom Kerekes Date: 2/22/2016
Hi David,
You might check if the A Axis is still defined in the System at the time it isn't moving from GCode by entering "DefineCS".
Does the A motor have holding torque?
Does it just vibrate rather than moving?
What does the KMotion Analog Screen show regarding the SnapAmp Supply voltages and Motor currents?
Have you tried a very slow feed rate?
Is the Peak Current Fault LED on SnapAmp come on?
What are your settings?
On 2/21/2016 4:28 PM, David Stevenson david.m.stevenson@... [DynoMotion] wrote:
David.
Hi David,
See:
> Hello Tom,
> Thanks,
> David.
www.avast.com
